Dessin sous CAO.
Post new topic   Reply to topic    "BricAuBoisAuFer" pour les 'Makers' du bricolage. Forum Index -> CNC - Computer Numerical Control -> Dessin de référence en DAO.
PostPosted: Sun 24 Feb - 12:22 (2013)    Post subject: Dessin sous CAO. Reply with quote
Ébauche de dessin le tête Y Z.
Longueur des rails du X est 1400 Mm & du Y de 800 Mm.
Last edited by Admin : PapyKy on Tue 1 Dec - 20:41 (2015); edited 4 times in total
PostPosted: Sun 24 Feb - 21:49 (2013)    Post subject: Dessin sous CAO. Reply with quote
Hauteur de passage & course de Z de 200 Mm.
PostPosted: Mon 25 Feb - 00:39 (2013)    Post subject: Dessin sous CAO. Reply with quote
Le dessin se monte doucement.
Last edited by Admin : PapyKy on Sun 26 May - 07:55 (2013); edited 2 times in total
PostPosted: Mon 25 Feb - 14:21 (2013)    Post subject: Dessin sous CAO. Reply with quote
Des info's des pièces des mécanique.
Last edited by Admin : PapyKy on Wed 27 Feb - 23:04 (2013); edited 1 time in total
PostPosted: Tue 26 Feb - 16:24 (2013)    Post subject: Dessin sous CAO. Reply with quote
J'ai du refaire ce dessin car mes pièces n'était pas a la bonne dimension.
Petite différence, non ?.
Last edited by Admin : PapyKy on Wed 27 Feb - 14:45 (2013); edited 1 time in total
PostPosted: Tue 26 Feb - 16:42 (2013)    Post subject: Dessin sous CAO. Reply with quote
Je crois que je vais attendre d'avoir les pièces pour continue les dessins.
Last edited by Admin : PapyKy on Sun 26 May - 07:55 (2013); edited 1 time in total
PostPosted: Wed 27 Feb - 23:06 (2013)    Post subject: Dessin sous CAO. Reply with quote
Accouplement & moteur sur vis, PapyKy.
PostPosted: Thu 28 Feb - 15:05 (2013)    Post subject: Dessin sous CAO. Reply with quote
Plans incomplet, mais en cours d'élaboration, PapyKy.
PostPosted: Thu 28 Feb - 20:58 (2013)    Post subject: Dessin sous CAO. Reply with quote
Moteur le l'axe "Y".
PostPosted: Fri 1 Mar - 16:15 (2013)    Post subject: Dessin sous CAO. Reply with quote
Last edited by Admin : PapyKy on Tue 1 Dec - 20:39 (2015); edited 3 times in total
PostPosted: Sat 2 Mar - 22:56 (2013)    Post subject: Dessin sous CAO. Reply with quote
PostPosted: Sat 2 Mar - 22:59 (2013)    Post subject: Dessin sous CAO. Reply with quote
Personne pour mettre un commentaire ?
PostPosted: Mon 4 Mar - 01:20 (2013)    Post subject: Dessin sous CAO. Reply with quote
Les plans se termine, encore quelques modification quand je recevrais les pièces principales.
Le plans est établi pour un usinage maxi de 1250 x 650 x 200 Mm.
PostPosted: Mon 4 Mar - 14:49 (2013)    Post subject: Dessin sous CAO. Reply with quote
Plans presque fini.
Dimension utile 1250x650x200 Mm
Last edited by Admin : PapyKy on Sun 26 May - 07:56 (2013); edited 1 time in total
Buxinien
Locomotion: HYUNDAI I 30
Loisirs: Bricolage, marche...
Date de naissance: 12/02/1950
PostPosted: Mon 4 Mar - 17:52 (2013)    Post subject: Dessin sous CAO. Reply with quote
Bjr,
Les dimensions me semblent intéressantes et je pense que l'on peut usiner des PVC, Bois et plaques ou tôles de non ferreux?
As-tu une idée du coût global de cette réalisation.
Es-tu intéressé par un partage au niveau réalisation ou travail en parallèle?
J-Ch
PostPosted: Mon 4 Mar - 19:22 (2013)    Post subject: Dessin sous CAO. Reply with quote
Bonsoir Buxinien.
Pas de problème pour l'aluminium, et même de la tôle d'acier en petite passe de 2 ou 3/10 de Mm.
Comme sur ces vidéo's.
et pleins d'autres sur le lien en signature et sur la chaîne de mon fils,
http://www.youtube.com/user/francmarccnc
Pour ce qui est du partage de réalisation, c'est pour cela que j'ai crée ce petit forum,
Pour partager ces compétences des futurs membres.
Quand au prix de cette réalisation, fait compter sans le temps passé entre 1000 à 1200 €uros,
Si l'on trouve tout ce qui faut a un prix raisonnable, Merci a "Google" & "EBay" pour cela.
Peut-être un peux plus si l'on doit tout acheter, reste a rechercher des récup's en tout genre.
Boitier, câble, vis, boulons et autre produits électrique.
Tout dépend de ce que l'on veut comme performance de "CNC Home made"
PostPosted: Tue 5 Mar - 11:59 (2013)    Post subject: Dessin sous CAO. Reply with quote
Élévation de l'axe "Z" de 200 Mm et la fixation de la broche va de 235 a 35 Mm au dessus du martyr de la table.
Sur une remarque de mon fils Marc, j'avais fait une grosse erreur, A++, PapyKy.
PostPosted: Wed 6 Mar - 21:10 (2013)    Post subject: Dessin sous CAO. Reply with quote
Le projet vient de prendre forme, a voir ICI.
http://cnc-papykyka.xooit.be/t472-Creation-d-une-NewCNC.htm#p1505
Les premiers travaux, PapyKy.
PostPosted: Fri 8 Mar - 21:05 (2013)    Post subject: Dessin sous CAO. Reply with quote
Attention il y a une autre page a la suite de celle-ci.
http://cnc-papykyka.xooit.be/t464-Pour-une-New-CNC.htm?start=25
Le montage, OUI c'est ICI.
Pas de critiques, 53 visiteurs sont venu voir du 23/02/2013 au 19/03/2013.
 Merci a vous d'avoir venu faire une visite sur le forum.
Last edited by Admin : PapyKy on Tue 19 Mar - 09:49 (2013); edited 6 times in total
PostPosted: Sat 9 Mar - 15:14 (2013)    Post subject: Dessin sous CAO. Reply with quote
Modification du plan.
C'est plus facile quand on a les pièces pour prendre les cotes, PapyKy.
PostPosted: Wed 13 Mar - 10:36 (2013)    Post subject: Dessin sous CAO. Reply with quote
Fixation des deux moteurs de l'axes "Z" "X".
Es-passé avec des entretoises de 55 Mm de long sur les vis de 6 Mm.
Last edited by Admin : PapyKy on Fri 15 Mar - 17:52 (2013); edited 3 times in total
Buxinien
PostPosted: Fri 15 Mar - 15:54 (2013)    Post subject: Dessin sous CAO. Reply with quote
Bjr,
Est-ce bien la fixation des moteurs de l'axe "Z" ?
Je pense que c'est pour l'axe des "X".
La cote de 80mm est prise à partir de l'axe moteur ou à un autre endroit? Je ne vois pas bien sur ton dessin.
Merci pour l'info. Okay
J-Ch
PostPosted: Fri 15 Mar - 17:51 (2013)    Post subject: Dessin sous CAO. Reply with quote
Bonne fin de semaine a toi Buxinien.
C'est bien juste, c'est l'axe "X" et non "Z", et une bonne note.
La cote de 80 est prise au dessus de l'axe de la vis qui fait 10 Mm de diamètre.
Pour déterminé la hauteur de la tôle du support moteur "X" moins 1 Mm au dessus
pour le tracé de la tôle qui a été découpée sur CNC chez Marc.
Ça fait plaisir de savoir qu'il y a un membre qui suit ma construction.
Merci a toi, je rectifie mon post de suite, PapyKy.
Buxinien
PostPosted: Fri 15 Mar - 18:52 (2013)    Post subject: Dessin sous CAO. Reply with quote
Bjr PapyKy,
Comme dit précédemment, ce projet m'intéresse!
Si ce n'est pas pas te demander, les plans en Autocad seraient-ils disponibles?
Si oui, je suis intéressé aussi.
Bonne fin de journée Mr. Green
J-Ch
PostPosted: Fri 15 Mar - 20:23 (2013)    Post subject: Dessin sous CAO. Reply with quote
Bon WE, Buxinien.
Oui c'est possible de faire un copie du fichier "*.DWG"
Mais il te faut "AutoCAD" pour le lire, si oui quel version a tu ?.
Tout est en vrac dans un seul fichier et une multitude de "layer".
Buxinien
PostPosted: Sat 16 Mar - 11:28 (2013)    Post subject: Dessin sous CAO. Reply with quote
Bonjour PapyKy,
J'ai la version 2011.
D'avance merci, tu veux, m'envoyer cela en perso sur mon adresse mail c'est super.
Je rentre de congé ce week end et je passerai aux choses sérieuses pour leprojet CNC.
J-Ch
PostPosted: Sat 16 Mar - 12:35 (2013)    Post subject: Dessin sous CAO. Reply with quote
Nouvelle évoluions du dessin de NewCNC.
Cette fois avec les bonnes cotes des pièces reçue.
PostPosted: Sat 16 Mar - 18:41 (2013)    Post subject: Dessin sous CAO. Reply with quote
PostPosted: Mon 18 Mar - 10:47 (2013)    Post subject: Dessin sous CAO. Reply with quote
Modification des plans d'usinage des gabarits de forage.
J’espère que celui-ci sera bon, Oh OUI, PapyKy.
PostPosted: Mon 18 Mar - 11:12 (2013)    Post subject: Dessin sous CAO. Reply with quote
PostPosted: Mon 18 Mar - 23:15 (2013)    Post subject: Dessin sous CAO. Reply with quote
Pas de critiques, 53 visiteurs sont venu voir du 23/02/2013 au 18/03/2013.
PostPosted: Sat 23 Mar - 10:53 (2013)    Post subject: Dessin sous CAO. Reply with quote
Renforcement portique a prévoir  en tôle de 10 Mm d'aluminium.
A++ PapyKy.
PostPosted: Tue 26 Mar - 01:30 (2013)    Post subject: Dessin sous CAO. Reply with quote
Palier support d"écrou de la vis a billes "Y".
Ce palier est fixer sous le chariot de l'axe du "Z" et sur le porte écrou de la vis a bille "Y".
Last edited by Admin : PapyKy on Tue 26 Mar - 09:16 (2013); edited 1 time in total
PostPosted: Tue 26 Mar - 09:10 (2013)    Post subject: Dessin sous CAO. Reply with quote
Traverse inférieur support des écrous des vis de l'axe "X".
Cette traverse est fixer au tôles du portique et supporte les écrous des deux vis a billes des "X".
Last edited by Admin : PapyKy on Wed 27 Mar - 00:53 (2013); edited 1 time in total
PostPosted: Tue 26 Mar - 10:19 (2013)    Post subject: Dessin sous CAO. Reply with quote
Petite fantaisie sur le support de broche.
PostPosted: Fri 29 Mar - 00:19 (2013)    Post subject: Dessin sous CAO. Reply with quote
Renfort sous table en bois de 12 MM.
A réalisé en bois résistant, hêtre bien sec de préférence pour évite les déformations.
Pas de hêtre a la dimension a ma disposition, alors du bois de palettes sera utilisé mais bien sec (plus d'un ans).
PostPosted: Sat 30 Mar - 12:36 (2013)    Post subject: Dessin sous CAO. Reply with quote
Petit dessin pour le placement des capteur du "Z".
Mais en fin de compte ne sera pas réalisé de cette façon.
PostPosted: Thu 4 Apr - 00:11 (2013)    Post subject: Dessin sous CAO. Reply with quote
Voici un dessin vite fait pour le montage de la broche de l'axe du "Z".
Sera coupé sur la CNC de mon fils Marc, a demain,
Mais voila je me suis trompé dans les cotes et l'usinage, serra refait, Eh oui, pas d'omelette sans cassé d'oeuf.
PostPosted: Sat 20 Apr - 21:07 (2013)    Post subject: Dessin sous CAO. Reply with quote
Pour être presque sans poussière lors d'usinage, il faut placer une aspiration le plus prés de l'outils.
Donc un petit dessin pour crée un capteur de copeaux.
Et pour etre usiné il faut crée un "Parcours d'outils" avec un autre logiciel.
Pour le "Loader" sur "Mach3" en GCode en mode "TXT".
A++, pour l'usinage, PapyKy.
PostPosted: Today at 01:59 (2019)    Post subject: Dessin sous CAO.
Post new topic   Reply to topic    "BricAuBoisAuFer" pour les 'Makers' du bricolage. Forum Index -> CNC - Computer Numerical Control -> Dessin de référence en DAO. All times are GMT + 2 Hours
