Obd1.
Post new topic   This topic is locked: you cannot edit posts or make replies.    "BricAuBoisAuFer" pour les 'Makers' du bricolage. Forum Index -> Automobile. -> Réparation du véhicule GVoyager S2 de service de PapyKy.
PostPosted: Sat 23 Nov - 23:30 (2013)    Post subject: Obd1. Reply with quote
https://www.google.be/search?q=obd+connector+pinout&tbm=isch&tbo=u&source=univ&sa=X&ei=OhyRUoODKcSUswbqs4DwDw&sqi=2&ved=0CC8QsAQ&biw=1280&bih=631#q=obd+connector+pinout+chrysler&tbm=isch&imgdii=_
Post new topic   This topic is locked: you cannot edit posts or make replies.    "BricAuBoisAuFer" pour les 'Makers' du bricolage. Forum Index -> Automobile. -> Réparation du véhicule GVoyager S2 de service de PapyKy. All times are GMT + 2 Hours
