CNC-PapyKyKa : HomeMade.
Moderator: None
Post new topic
No new postsTravaux en cours Announcement: Fixation sur table CNC.
Des cames qui ce fixe sur la table. 4803 visites.
10 Admin : PapyKy 5,416 Tue 14 May - 08:04 (2019)
No new postsheart Announcement: La CNC chez PapyKy
L'histoire de la famille
3 Admin : PapyKy 4,813 Thu 22 Mar - 11:19 (2018)
No new postsCinKa Announcement: "CinKa-CNC", Sa création HomeMade - 550 x 360 x 110 Mm.
Format B3 (A3+, 500 x 353 Mm), tout aluminium. 1523 visites.
[ Goto pageGoto page: 1, 2 ]
80 Admin : PapyKy 8,687 Thu 22 Mar - 11:16 (2018)
This topic is locked: you cannot edit posts or make replies.CinKa Announcement: "CinKa-CNC", Les dessins pour sa création en aluminium.
Tubes 40 x 40 & 60 x 40 Mm. 434 visites.
36 Admin : PapyKy 4,749 Sun 8 Jan - 22:53 (2017)
No new postsCinKa Announcement: "CinKa-CNC", Rapide & usage léger au Format A3+.
CNC aluminium, courroies sur rails de 12 Mm axes 'X & Y".
6 Admin : PapyKy 2,204 Mon 2 Jan - 21:29 (2017)
This topic is locked: you cannot edit posts or make replies.UneKa-CNC Sticky: "UneKa-CNC" - 1250 x 640 x 200 Mm.
CNC chassis acier & vis a billes - 11425 visites
[ Goto pageGoto page: 1, 2, 3 ]
145 Admin : PapyKy 27,812 Sat 10 Dec - 14:23 (2016)
This topic is locked: you cannot edit posts or make replies.LayKa-CNC Sticky: "LayKa-CNC" - 800 x 455 x 80 Mm.
CNC a courroies T5 (EX "CNC-Festool") - 6309 visites.
90 Admin : PapyKy 14,172 Sat 10 Sep - 22:22 (2016)
No new postsUneKa-CNC Sticky: "UneKa-CNC" Va recevoir une broche 400Hz de 1500 W.
Préparatif de montage d'un broche sur CNC.
3 Admin : PapyKy 2,625 Mon 20 Jun - 19:44 (2016)
No new postsDeuKy Sticky: "DeuKy-CNC" - 850 x 550 x 155 Mm
CNC de type pont roulant. 6698 visites.
[ Goto pageGoto page: 1, 2, 3, 4 ]
174 Admin : PapyKy 18,737 Sat 18 Jun - 08:51 (2016)
No new postsTroKa Sticky: "TroKa-CNC" Tour modifier en CNC.
MadeChinois BV20-L - 500 Mm d'entre-pointe. 6362 visites.
107 Admin : PapyKy 20,522 Tue 14 Jun - 19:42 (2016)
No new postsUneKa-CNC Sticky: "UneKa-CNC", Fait du travail sur bois & PVC.
Usinage divers. 1251 visites.
29 Admin : PapyKy 5,656 Fri 22 Apr - 13:17 (2016)
No new postsDeuKy Sticky: "DeuKy-CNC" Et sont systeme de lubrification.
En préparation, air et eau blanche.
1 Admin : PapyKy 3,066 Sun 26 Apr - 08:54 (2015)
No new postsinfo Remontage d'un écrou de VAB.
C'est pas facile, mais réalisé.
2 Admin : PapyKy 2,751 Wed 18 Apr - 19:43 (2018)
Gabriel View latest post
No new postsheart Soviet Créatif Market. 09-2016.
Participation a une foire d'artisans.
2 Admin : PapyKy 2,283 Mon 12 Sep - 09:36 (2016)
No new posts  Make Wallonia, et autres Broc.
Des Makers, Personne qui présente leurs hobby. 269 visites.
8 Admin : PapyKy 2,823 Mon 6 Jun - 11:19 (2016)
No new postsLayKa-CNC Des roues type chemin de fer, par LayKa-CNC.
Mais pas seulement, d'autre usinage en MDF.
16 Admin : PapyKy 2,655 Fri 8 Apr - 21:07 (2016)
No new posts Pour un projet d'un CNC de dimension raisonnable.
Du genre de 900 x 650 x 150 Mm, suivant le kit des rais et VAB.
2 Admin : PapyKy 2,608 Mon 7 Mar - 01:21 (2016)
No new postsheart Fabrication d'un aspirateur cyclone.
Pour les fines particules que la CNC fait dans le bois.
8 Admin : PapyKy 4,326 Sun 30 Aug - 13:43 (2015)
Mecano655 View latest post
No new posts  Nouveaux type de moteur pas a pas pour CNC.
HBS57 Drive + 573S09EC Motor.
2 Admin : PapyKy 2,920 Tue 4 Aug - 23:30 (2015)
This topic is locked: you cannot edit posts or make replies.DeuKy Le projet CNC Mystère à changer de non., et devient "DeuKy-CNC".
La conception & les dessins avant tout. 1440 visites.
37 Admin : PapyKy 5,748 Sun 21 Dec - 14:35 (2014)
No new posts  Découpe de dessin.
A testé & a voir si réalisable.
0 Admin : PapyKy 2,802 Tue 9 Sep - 08:51 (2014)
No new postsheart Montage d'un boitier puissance pour CNC.
Pour remplacer celui de "LayKa-CNC". 1329 visites.
20 Admin : PapyKy 5,188 Thu 5 Jun - 12:48 (2014)
No new posts  Test dynamique d'un moteur PàP.
Sur une vidéo de la toile.
0 Admin : PapyKy 2,754 Tue 27 May - 13:38 (2014)
No new postsUneKa-CNC L'ordinateur de UneKa-CNC.
Aménagement.
2 Admin : PapyKy 3,130 Wed 15 Jan - 22:13 (2014)
No new posts  Belle réalisation de CNC Homemade.
Trouvé sur la toile.
0 Admin : PapyKy 3,527 Tue 31 Dec - 13:04 (2013)
No new posts  Tutorial sur VCarve-Pro.
4 Admin : PapyKy 7,132 Fri 24 May - 09:56 (2013)
No new postsUneKa-CNC Premiers essais "UneKa-CNC"
Papier et Marker / bois.
8 Admin : PapyKy 3,342 Wed 22 May - 07:00 (2013)
No new postsLayKa-CNC Projet & modification de "LayKa-CNC".
Fournitures et réalisation des plans.
2 Admin : PapyKy 3,124 Mon 13 May - 18:53 (2013)
No new postsUneKa-CNC Boitier commande "UneKa-CNC".
4 blocs de puissances 2M542 4.2A.
15 Admin : PapyKy 5,831 Thu 18 Apr - 00:00 (2013)
This topic is locked: you cannot edit posts or make replies.UneKa-CNC Projet de "UneKa-CNC".
Fourniture et réalisation des plans.
6 Admin : PapyKy 3,498 Fri 8 Mar - 21:03 (2013)
No new postsC'est fait. Boitier commande CNC.
Carte chinoise 4 axes
3 Admin : PapyKy 4,451 Sun 27 Jan - 10:47 (2013)
No new postsHusKy "HusKy-CNC" Projet avorté, mais pourrais devenir un découpe plasma.
Premier projet CNC de PapyKy. - Mais là je n'y connaissais rien. - 2800 visites.
11 Admin : PapyKy 6,050 Sun 27 Jan - 10:45 (2013)
Display topics from previous:
Post new topic    "BricAuBoisAuFer" pour les 'Makers' du bricolage. Forum Index -> CNC - Computer Numerical Control -> CNC-PapyKyKa : HomeMade. All times are GMT + 2 Hours
